idle problem 90 accord dx?
Old Nov 25, 2006 | 02:32 PM
RotnikVW's Avatar
Default idle problem 90 accord dx?
So my 1990 Accord has had an iratic idle lately. I'm pretty sure its some sort of vacuum leak. You can hear a whistling coming from the engine bay while driving it almost sounds like a turbo. Then when you shut the car off you can hear a loud whistling like air escaping from somewhere. The idle doesn't drop lower then where it should be, but it pulses up and down consistantly, with worse jumping when the car is cold. The whistling sounds like its coming from the drivers side of the engine bay, but I cannot find out where it is coming from. Anyone have any ideas?
Old Nov 25, 2006 | 10:09 PM
Default RE: idle problem 90 accord dx?
take a can of starter fluid, use caution where you spray, at engine idle, spray around lines little at a time. when engine idle increases, leak may be in that area, usually a hose or at a fitting.
Old Feb 28, 2007 | 01:55 AM
Corbuston's Avatar
If it just happends not to be any leaks in vacuum lines then check ur IAC valve or u Idle position senser i am having the same problem with my honda prelude. i had to IAC Valve cleaned and that took care of the problem for awhile but its back to doin it again so that would just be a temporary fix.
bcole6
Apr 30, 2013 09:30 AM
DanielH33
Aug 18, 2008 11:10 AM
86_accord2.0
Aug 1, 2007 05:50 PM
alexk
Feb 1, 2007 11:24 PM
BigDan
Jul 25, 2006 12:22 AM
