jdm engine swap h23 to f22b
Old Oct 24, 2010 | 01:48 PM
racerrick's Avatar
Default jdm engine swap h23 to f22b
ok here we go 92 prelude with a jdm motor and a us harness. ended up with 2 extra wire connectors.1 is green 2 wire in the dist harness.the 2nd is on the pass strut tower and is gray 2 wire.(see pics) the fans do not come on and the check engine light is on.is there a way to pull codes with out a scan tool?
does any one have a vacuum hose routing chart? thanks for any help you can give us
Attached Thumbnails jdm engine swap h23 to f22b-img00782%5B1%5D.jpg   jdm engine swap h23 to f22b-img00783.jpg   jdm engine swap h23 to f22b-img00784.jpg
Old Oct 24, 2010 | 01:52 PM
Welcome to the forum,our Mod 91haydenSI can probably help you with that when he reads this good luck.
Old Oct 30, 2010 | 07:59 PM
racerrick's Avatar
any ideas?
rogue
Jul 12, 2015 09:49 PM
tullum86
Jan 12, 2014 01:02 AM
tx93f22a1
Sep 16, 2009 09:51 PM
92lude2009
Mar 17, 2009 06:57 AM
os1r1s1
May 10, 2007 10:41 AM
