jdm engine swap h23 to f22b
3 Attachment(s)
ok here we go 92 prelude with a jdm motor and a us harness. ended up with 2 extra wire connectors.1 is green 2 wire in the dist harness.the 2nd is on the pass strut tower and is gray 2 wire.(see pics) the fans do not come on and the check engine light is on.is there a way to pull codes with out a scan tool?
does any one have a vacuum hose routing chart? thanks for any help you can give us |
Welcome to the forum,our Mod 91haydenSI can probably help you with that when he reads this good luck.
any ideas?
| All times are GMT -5. The time now is 08:44 AM. |
