Key remote switches stopped working HONDA Accord 2005
Honda Accord 2005 2 door coupe LX. Passenger window had not been working for some time, would not go up or down.
Replaced window regulator/motor with a new one from dealer. Still would not work so master window switch was replaced with a used one. Everything now works(both windows, side mirror controls) but key remote no longer locks/unlocks doors or opens trunk. Battery is good. Is there a fuse that might have blown? Is there some programming that needs to be done? I have an ignition key with the lock/unlock/trunk buttons. Thanks. |
If it were a fuse it would not work some of the time,look for a loose power supply or ground.
| All times are GMT -5. The time now is 08:16 AM. |
