keyless fob/and receiver info
Old 11-14-2016, 07:42 AM
bugsb's Avatar
Default keyless fob/and receiver info
i could not find anything under hrv so hope this is is the correct section
my problem
honda hrv 2002 matching fob too receiver
when i bought the car the fob would not work and would not sync to the car so i sent it off and told it must have been in water as it could not be repaired i used this guy before and had good results to the point if he cant fix it it cost nothing apart from the postal cost
so the fob code having got wet had been washed off the back and the circuit board next step look at the receiver most hondas have the fob code on that like g8d-344h-a simple you would think but not on the hrv it has a unknown code which if anyone can help with i would be grateful the one in the picture is not mine but the same unit and am guessing the tag bottom left is the code so this is where i need the help i cant find anything to do with that type of coding if anyone can help i will post the code i have
Ron
cdoody
08-01-2016 01:12 PM
Hieu T. Mai
04-19-2014 06:42 PM
petjunior
08-13-2008 10:30 PM
trimsaran1
10-03-2006 06:25 AM
nrl073
08-30-2006 02:20 PM
Quick Reply: keyless fob/and receiver info
