Need Help w/94 Accord Headlight Problem!!
Right lowbeam not working. Replaced right headlight twice w/correct replacement and still does not work. Highbeam works fine on both sides. Any ideas?
RE: Need Help w/94 Accord Headlight Problem!!
welcome to the forum, providing the left side low light works, check the wiring from the plug back to see if there is power on the right side. may be a cut line or a loose connection. make sure your light socket plug is clean.
