No parking lights and dash lights?
Checked all fuses think it might be the switch why do you guys think?/Its a 1996 honda accord. [X(]
[/align] |
RE: No parking lights and dash lights?
yup.
ok changed switch and checked bulbs i found like 4 bulbs burned out could that affect all the other stuff?
ORIGINAL: marky4 ok changed switch and checked bulbs i found like 4 bulbs burned out could that affect all the other stuff? |
[quote]ORIGINAL: golfer
ORIGINAL: marky4 ok changed switch and checked bulbs i found like 4 bulbs burned out could that affect all the other stuff? I mean like the dashboard. This is what i did so far check all the fusesunder hood and under driver left side all were good. Then i thought it could of been the headlight & parking light switch, changed that and still didnt work. then i checked all the light bulbs and put new ones. But still they dont work.. So i dont know what else i could do i think maybe i am going to take it in so they can look at but i know its going to cost a bunch... |
If possible, get your hands on an ohm meter and see if there's any power actually coming to them or not. Or just start tracing and make sure all wires are in working condition. This of course is hard to say based on the fact that i'm not sure what bulbs you were talking about replacing and what exactly isn't working. are you talking about your cluster lights?
1)Check your bulbs first....2) check your fuses......3)check the wiring with the a tool they have these at advanced auto parts tell them the problem
| All times are GMT -5. The time now is 10:14 AM. |
