No throttle response at 2000RPM
Old Nov 18, 2014 | 12:59 PM
Rgmgpg's Avatar
Default No throttle response at 2000RPM
98 civic ex all stock 210000 mi. When slowing down for a light engine rpm around 2000 instead of stopping the light turns green and when i try to accelerate the engine goes to an idle. The car does not shut off but will not accelerate. Lift off the throttle completly and then it may come back about 3 or 4 seconds later. Doesnt do it every time. Sometimes hard to start. Car runs great at 3000rpm. No CEL. Fuel press good. Checked TPS, MAP sensor, replaced PCV with OEM, no vacuum leaks, replaced IAC valve, checked O2 sensor. Found secondary winding of coil to be out of specs replaced with OEM. If the car will not start next i will try the CKP sensor. Anyone have this problem please help, thanks
Old Dec 11, 2014 | 11:33 AM
Rgmgpg's Avatar
Went back to the basics. Changed distributor cap and rotor and put a new set of wires all honda oem. Kinda disappointed no help from anyone out there
Old Dec 14, 2014 | 07:52 AM
Is the throttle body sticking at 2000 mabe,if so clean it with throttle body cleaner NOT carb cleaner,see if that helps. If not the throttle position sensor may be bad.
Old Dec 15, 2014 | 08:46 PM
Rgmgpg's Avatar
It was the cap and rotor
tgt47
Apr 17, 2013 11:55 AM
jinpdx
Mar 1, 2013 12:54 AM
High V3l0c1ty
Nov 20, 2006 01:18 AM
High V3l0c1ty
Oct 18, 2006 09:53 PM
hecyeah
May 28, 2006 12:20 AM
