oil lost
welcome to the forum. Who changed the oil? Was the oil level checked after the oil and filter was changed and engine idled for a minute or so.. If you are loosing/burning this much oil, with no oil leaks you should have white/blue smoke out of your exhaust heavy. Oil has to be going somewhere or burning it.
i changed the oil, and i did check the level, no leaks and no blue or white smoke coming out the tail pipe. but i did notice the remaining oil is very dark, i only driven less then thousend miles after the oil change, thanks
Check the oil level each week and notice how much oil is being lost, also if the oil is dark, usually means, the oil is cleaning the engine. Or the oil is being changed with too many miles. Normal oil change is 3-5k with the newer and better oils. What type oil are you using on your civic?
Welcome to the forums... the oil may be getting burned off it just may be so slowly that the smoke isnt very visible.. also check for small leaks while the engine is running.. it could be an oil pan gasket but that wouldnt leak unless the engine is running.
depending on driving style. if the car is using 3-4 qts in less than 2k miles, the oil ring could be gummed up. Have you tried lucas engine restore, this sometimes frees up gummed up piston rings and oil rings. I have also tried mystry oil, it cleared up the gummed up rings, but it made my rocker arms rattle for a while until I put in a bit heavier oil eng had 160k "Escort" oil burn dropped from 2 qt per 1k to 1 qt per 2k miles.
forgot to mention, to check your pvc valve, and filter (if installed) and make sure it is working freely.
