parking brake adjustment
On a 2017 Honda Accord Coupe Touring model - how do I adjust the parking brake? It needs to be pulled up a lot more than other Honda's that I've compared it to and I'd like to tighten it up a bit - thanks for any info.
welcome to the forum. i believe the adjust is just rear of the handle in a square access (where you might throw coins and junk) there is a square panel open with a flat tip screw driver and the adjust should be under there, using a 12 mm wrench.
