Power seat won't go up/down '03 Accord
2003 Accord. Starting having issues where the seat would go down, but not up occasionally. Now, it's down and won't go back up.
Is there a way to force the seat to the up position? I don't care to move it back to the low position if I can raise it manually. Or, how best can I test if it's a bad switch, motor, etc. Thanks. |
The plug to the motor will have two large wires and they should read low ohms.
Do you have a dvom? |
(Post 40232)
Do you have a dvom? Hi thanks. I have a meter. Are you saying to measure the resistance at the motor or the wires? |
You want to measure the motor windings not the wires. If the windings are open the motor is junk.
(Post 40234)
is there a way to manually raise the seat? I never have the need to lower it, if I can raise it I’d be happy. |
I'm pretty sure you'll need to pull the seat to do that.
| All times are GMT -5. The time now is 09:40 AM. |
