-   -   Problem with the petrol gauge (https://hondaforum.com/forum/general-tech-help-37/problem-petrol-gauge-8315/)
Still learning Mar 19, 2013 07:17 PM
Hi everyone,
My wife put to much gas in the tank of our 2007 Honda Civic. Since that time the petrol gauge remain full.
Is there something, I can do?
Thanks
lowlife9 Mar 19, 2013 07:27 PM
you can't really put to much gas in a gas tank that wouldn't cause a problem. so either its the gauge itself or maybe the float in the gas tank. try using a fuel cleaner and see if that works maybe some Seafoam brand . or gain access to the float in the tank.
Still learning Mar 19, 2013 07:49 PM
So you're sure that the problem is related to the fact that my wife put to much gaz in the tank?
Do you know, if it cost a lot to repair. I have no talent in mecanics... If so how much do you think it's going to cost me.
Thanks
acmech52 Mar 20, 2013 05:02 AM
welcome to the forum. if it is the float, the cost is approx 150.00 plus the fuel tank usually needs to be dropped to r & r the float. takes approx 3.5 hrs to drop and reinstall the tank ( est ) Honda labor is about80 to 120.00 per hr depending on dealership. Find a good shop AAA rated and get some estimates. filling up the tank max does not make the float stick.
lowlife9 Mar 20, 2013 07:31 PM
if its setup like a civic i don't believe you have to drop the tank. you gain access to the fuel pump and float via under the backseat but i could be mistaken.
acmech52 Mar 21, 2013 06:38 AM
you may be correct lowlife9. last one I worked on was a 90 accord. i did gain access from the back of the back seat.
lowlife9 Mar 26, 2013 07:34 PM
just found this thought it could help http://www.civicforums.com/forums/3-...ding-unit.html
