question on turbo mods for integra DC5
Hi :-
I bought a DC5 recently and want to fit a Greaddy turbo systems in it, but i been told if i fit a turbo, it will screw up the readings on the ECU and will cause the engine light come on.
i need to know is there a way to have the turbo fitted with the car running correctly without the engine light coming on?
also if there any other information what i need to do for fitting a turbo plz let me know .
many thanx
many thanx
RE: question on turbo mods for integra DC5
the only real good option you have is to put in a hondata system. the hondata will 'piggyback the factory ECU and run all your settings for your turbo. THe check engine light will not come on because the hondata tricks your ECU into thinking its not there and the hondata system takes care of the fuel and air ratios to suit the needs of the turbo.
k24hatch
10-15-2013 08:20 PM
