Question on using loctite
I have taken the side drive belt cover on my Honda Elite 110 scooter, the one pictured below. Simple question as haven't done this type of work before. Do I want to use loctite on the bolts when I put the cover back on? Also if I should use loctite would the lowest strength purple be my best choice. Thanks in advance.
https://cimg7.ibsrv.net/gimg/hondafo...3d83d6496c.jpg |
just a heads up, when using Loctite, this means you do not want the bolt/nut to ever back off. you may have difficulty taking it apart in the future.
Probably not necessary but if you use some, use the blue 242.
Yes ,as stated above be careful there are varying degrees of strength in loctite,use the purple.
