rack wrench
Old Sep 15, 2014 | 09:18 PM
rclc's Avatar
Default rack wrench
Looking for the wrench that is used on a 1994 EX Accord steering rack adjustment nut. Believe 40mm
Old Sep 15, 2014 | 11:59 PM
lowlife9's Avatar
the honda part # is 07AAA-TL2A100 so google that
Old Sep 16, 2014 | 08:12 AM
rclc's Avatar
Tks Lowlife9, I have a persistent leak from that large nut. Do you know if there is a small o-ring or washer used with that nut and other than losing fluid can I completely take if off and place and o-ring on it, Tks
Old Sep 16, 2014 | 01:36 PM
lowlife9's Avatar
i believe there is a washer and O-ring between the rack guide and the rack guide screw yes. http://www.hondaautomotiveparts.com/...BOX+COMPONENTS
Old Sep 16, 2014 | 04:28 PM
rclc's Avatar
lowlife9---Tks a millon. Will let you know my results. Did the rack install and can't believe I have this leak around the 40mm nut.
Old Sep 27, 2014 | 02:39 PM
rclc's Avatar
got wrench, new seal, installed, and has you probably guessed the leak is from the hose fitting directly to the top and some what right from the lock nut looking up from the bottom left. Oh Boy.... Good news is that I have a special tool ($30.00) that I will probably never use again. I will lend it out if anyone needs. Bad news I may have to pull the rack..
namxas
Jul 12, 2009 01:44 PM
chillbilly9
Jul 9, 2008 11:11 AM
mntldfct
Dec 20, 2007 11:50 AM
neumspace
Jul 13, 2007 02:10 PM
spear
May 3, 2007 04:09 PM
