Replacement Blinker Assembly for an '02 Civic Hatchback
Hello,
I drive an '02 Honda Civic Hatchback Si and was recently involved in a hit and run. The jerk sped away and, with liability, I was unable to properly get my car repaired. The other car took out my Driver-side headlight and jacked up my fender. I ordered and replaced the headlight, however my (blinker assembly?) is completely crushed. Ordering headlight kits online do not come with the blinker socket part that I need. I have checked my local salvage yards here in Wichita Kansas, but none have a compatible car at the moment. I scoured eBay, but have been unsuccessful in finding a replacement part. It might help if I was certain about what this part is called. Does anyone know the proper term for this piece and do you know of a good place to get a replacement? Thanks in advance everyone. |
welcome to the forum. if you go to hondaautomotiveparts.com or any on line Honda parts, you might be able to look up the part you need for reference and be able to google the part nbr or named item to see if it comes up.
you could try rock auto
You can also try going to HondaPartsCheap.Com. they have all the exploded views and part numbers you'd need to find out what it's called.
If the part you need is the actual light bulb socket, they are sometimes part of the engine compartment wiring harness, which you don't want to replace if you don't have to. If that's the case, you're probably better off waiting for one to appear in a salvage yard so you can cut the socket out, and wire it into your car. Good luck. H&R sucks. |
| All times are GMT -5. The time now is 08:42 AM. |
