Rev limiter in at 8000
Old Dec 19, 2006 | 08:09 PM
gasman's Avatar
Default Rev limiter in at 8000
Having problem with what seems to befactory revlimiter ,Installed cams, msd sci ignition , blaster 3 coil on 95 integra v-tech with 8500 rev limiter in chip in the msd, but still shuts down at factory 8000rpm.when I install a lower than 8000 chip in the msd it is limited at that chips limit and works fine want to run 8900 chip but cant break the 8000rpm thought ignition upgrade bypassed factory rev limiter, this is on my friends car what did we miss .
Old Jan 6, 2007 | 05:25 PM
kornfox's Avatar
Member
Default RE: Rev limiter in at 8000
I dont know the specific fix for your problem but I have some hearsay on a generic fix. A friend of mine supposively had a similar issue. He said while driving he would rev up to the rev limiter, after it kicks on, he would wait until he could throttle it again and hit the same RPM. He said after doing it 4 or 5 times it "burnt out". I dont know how fun that is on the motor, or if it has any validity whatsoever, its just what he said worked. If you find a worthwhile solution, fill us in! Good luck.
Zander84
Mar 27, 2012 08:47 AM
nlomonte
Jul 17, 2010 03:05 AM
spike817
Sep 4, 2009 02:51 PM
neonstryde
Dec 9, 2007 07:08 PM
SlickRick23
Mar 7, 2007 11:59 PM
