reverse lights not turning on...
i have a 96 civic cx swap ls, i just had the car a few weeks now and JUST noticed that my reverse lights aren't turning on...any suggestions? all will be helpfull...thanks!
RE: reverse lights not turning on...
welcome to the forum, check the bulbs to make sure they are good, also check to see if you get power to the bulbs, then check the reverse switch has power to it. If the reverse switch has power, and you shift in to reverse and there is no light, switch bad.
