Reversing motor rotation
I want to run an LS motor in my sand rail. The problem is that the motor turns counterclockwise while the transmission is set up for a clockwise motor. Is there aNy way I can change the rotation of the motor, or possible change the gear ratio in a Honda transmission to be used in the sand instead of a vw transmission?
| All times are GMT -5. The time now is 08:26 AM. |
