s2000 performance trans
Old Jan 24, 2009 | 08:29 PM
voodoo216's Avatar
Default s2000 performance trans
im working on a 2002 s2000 it is suppost to have a performance trans in it. scym#i035599 it may be a 1035599 i need to find out if it is. and where i can get info on slave cylinder rods for push pull set up. one of the rods is broke and one is bent. thanks for your time
Old Jan 25, 2009 | 08:02 PM
Default RE: s2000 performance trans
welcome to the forum, we have a new member call transguy37, he might be able to help you with the transmission question. email him or post a question under his post. Hope we might be able to assist you.
Old Jan 29, 2009 | 06:57 PM
transguy37's Avatar
Hello,
There should be a tag on the trans somewhere of the company that made this trans a performance trans. If there is not a tag, then it is just a stock trans. As far as I know as of now, their are not any aftermarket perfamnce gears or synchros available for this unit yet. I'm not saying that it's not, but I doubt that it is. The rod will probably be a dealer item only right now. i can check if yiou need me too though. Hope this helps.
atrain33
Aug 4, 2011 07:05 PM
gainesjs
May 26, 2008 05:22 PM
supertank
Dec 4, 2006 02:24 AM
john
May 22, 2006 09:21 AM
greendolphin
Mar 29, 2006 04:48 AM
