-   -   Should I patch my windshield or replace it in my case? (https://hondaforum.com/forum/general-tech-help-37/should-i-patch-my-windshield-replace-my-case-18015/)
theateist Jan 6, 2026 12:15 AM
I’ve seen a lot of videos where people repair different kinds of "spider" cracks in windshields. Would you consider my crack (in the middle of windshield) to be a large one that really requires a full windshield replacement, or is it reasonable to try a DIY repair kit first? My thought is to use a kit initially, and only replace the windshield if the repair doesn’t hold or if the crack grows over time. Does that make sense in my case?
https://cimg8.ibsrv.net/gimg/hondafo...ce15637bb6.jpg
https://cimg9.ibsrv.net/gimg/hondafo...8266e247d9.jpg
grcauto Jan 9, 2026 08:14 PM
If you can get a vacuum on it (may cause it to grow a little) and suck in super glue from the other side. If it sucks it in it'll keep it from growing when done.
jacobgary Jan 26, 2026 08:17 PM
Originally Posted by theateist (Post 46372)
I’ve seen a lot of videos where people repair different kinds of "spider" cracks in windshields. Would you consider my crack (in the middle of windshield) on my UForce 600 Front Tinted Rear Windshield to be a large one that really requires a full windshield replacement, or is it reasonable to try a DIY repair kit first? My thought is to use a kit initially, and only replace the windshield if the repair doesn’t hold or if the crack grows over time. Does that make sense in my case?
Yes, it makes sense to try a DIY repair kit first, as long as the crack is not too large and you monitor it closely. If it spreads or affects visibility, you’ll need a full windshield replacement.
