Strange start and then die problem
Hi everyone,
This is a 2010 Honda Odyssey 65K. It has been running well until now. After not using it for many days because of the covid-19, I tried to start it. It cranked, started, and died after a few seconds, and the battery icon lighted up at the dashboard. When starting, the RPM did go up. Here is the video link: 2010 Honda Odyssey start and die 1 I have tried the followings:
I also tried to press the gas when starting, the RPM will shoot up but it will still die after a few seconds. Here is the video where I tried twice to start the car. The first time at 0 to 0:14, you can see the RPM has the second “up”, and the second time (0:16-0:24), I simultaneously pressed down the gas paddle and the RPM shoot up and then come down. Tried to start the car after cleaning the throttle body and pressing down the gas paddle 1 I don’t know what to do next. Please advise. Thank you all! |
Just a guess, ....
Check the EGR system |
Originally Posted by avisitor
(Post 36353)
Just a guess, ....
Check the EGR system Thank you for your advice! Could you be a little specific on why and how I should check if the EGR system is the problem? I am new to diagnose by myself. Your help is greatly appreciated! |
Sometimes carbon or grease builds up and clogs.
Cleaning should help it run better Check youtube videos if you need reasons why or how to do this They are more detailed and show you the process Good luck |
Sounds like a fuel delivery problem ,rather than electrical, I would examine that area.
