Transmission problems?
hello again everyone I really need some help at this point I have a 1994 honda accord EX apprx.200k miles it had a used transmission in it. Last week I had to replace the engine because the bearings were bad.
Here is the problem After I put the engine in and started up the car the cooling fans would only come on when I ran the AC so I checked the connections to the fan and fuse and relay all seem to check via volt an ohm meter test. following the shop manual it lead me to 2 things the fan control modual and a diodie neither of which I can locate can any one supply me with location or photo With that said I took it out for a test drive yesterday night and as i was moving forward at about 15 mph the car wouldnt move any more nothing from any of the gears R D1 D2 when I attempted to put it in park i started to make a grinding noise so I just left it in netrual and had it towed home. Any suggestions. Thanks everyone I can sure use the help |
Sounds like the Transmission may have given up also,here is some info on the ."Radiator Fan Control Module," this module can only be accessed by removing the "Glove Box Compartment," inside the vehicle. Not as difficult as it sounds to check and replace.
Fan Controls Component Location Index, http://tinypic.com/r/10z0dqo/7, Radiator Fan Control Module, http://tinypic.com/r/2hzqyiv/7, and Cooling Fans Relays, http://tinypic.com/r/htwfft/7. Hope this helps :D |
| All times are GMT -5. The time now is 07:36 AM. |
