trouble removing clutch
well im replacing my clutch that completely fell apart after my pilot bearing broke,still wondering how that happened, and i cant seem to be able to remove any of the bolts on the pressure plate.:confused: im using a 12 point wrench and having my buddy keep the engine from turning by keepin breaker bar on pulley. any recommendations or opinions would greatly be appreciated.
its hard to explain but get your wrend and apply oppsite direction torgue on it but hit the top of the wrench the the left with a hammer i know it sounds weird. ill try to explain better grap the wrench close to the head and apply torgque to the right on it then hit the bottom or the wrench towards the left (to break it loose) with a hammer do this a couple of times and it will loosen up.
find a 12 point socket a get an impact gun
smithteddy123, will you please explain what was pressed in undesired way, and what wires came loose trying to remove a pressure plate?
