What isz Makin my car cut off?!
Hey, and thankx for takin the time to read this thread n helping n advance. Im goin to try n explain all the things ive bn n wat my car is doin 2 try n find an answer. I own a 99 accord coupe and ive bn havin nuffin but problems wit it cuttin off! I first bought the car n it cuz off it was the wiring behind the ignition switch...after that was replaced it wud continue to cut off n become very difficult to crank when it cuts off.
i had my motor replaced by jim brady,(acura and honda specialist in Spartanburg Sc) because the baring n the motor was goin bad when i bought it. the car is doin the same thing after swappin the motor. i dont believe it has sumthing to do wit the motor. i had an automatic transmission put n as well when i bought the car (transmission put n my B&E transmission). How the car reacts: 1. if i crank the car on it will quickly idle low n cut off... 2. when it cuts off very thing is on except for the motor... 3. becomes difficult to crank.. 4. if im driving it n i slow down sumtime it will cut off. 5. check engine light does not come on when dis happens ive recently bn getn a range sensor every other month for the transmission. i also have a 800 watt amp wired from my fuse box...the problem wit the car happened b4 i installed it but happens more often now. The range sensor put on the car was not from honda n i think the sensor shorting out is the reason it cuts off?! any suggestion?!?!:( |
try and remove the sensor and wire ur amp off the battery and see if that does anything if not replace ur mass air flow sensor those have a tendency to go out
just rewire the amp with its own fuse box off the batter. check the map sensor and o2 sensors too
