05 accord interior lights not working
We recently purchased a used 05 Accord. The interior lights are not working. They do not work when trying to turn them on or when the doors open. The fuses are all fine and power is going to the fuse box. What should I check next? I am doubtful the bulbs are burned out - it doesn't make much sense that all of them are burned out.
Any suggestions? Thanks!
RE: 05 accord interior lights not working
welcome to the forum. If you have power on both sides of the fuse, you will need to follow the wires to the interior lights, some place where they have a common connection, it is loose or broken. Get a wire diagram for your car and see where the connectors are. The library may have the manual for the wiring.
JennyBoo311
03-04-2021 08:06 PM
cookiekare
09-24-2019 12:27 AM
