'07 windows
I did a search and couldn't find anything,,,i have a 2007 accord,,all power windows except the driver window will not work,i can hear a clicking sound with either master or individual switch. I checked the 50amp p.window fuse under hood and it's fine,,however,,there are individual fuses under dash,,4 for each door,,i only have power to the only one that works(drvr.wndw),.,.,..any suggestions//help would be greatly appreciated..thanx
I would suggest first trying to get to the connections on the master switch in the drivers door by removing the door panel,check the connection and if the switch is getting power,if the switch is faulty replace it, they run about $125 on line.I have a feeling the connection is loose,let us know Good luck,Bobby
Help,,the master switch does have power,,the driver window works fine,you can hear clicking in the other doors when trying from main switch,,,the question is,,,there are 4 fuses for each window,,I checked with testlight there is only power to drvr wndw fuse,,which that one does work fine,,the other 3 individual fuses have no power at all.Is there a seperate relay or something,,this make no sense at all to me.
arcedence
Sep 17, 2008 06:40 AM
Neyne
Mar 23, 2008 09:20 PM
