-   -   '07 windows (https://hondaforum.com/forum/honda-accord-forum-11/07-windows-7056/)
tng6664 Feb 24, 2011 12:01 PM
'07 windows
I did a search and couldn't find anything,,,i have a 2007 accord,,all power windows except the driver window will not work,i can hear a clicking sound with either master or individual switch. I checked the 50amp p.window fuse under hood and it's fine,,however,,there are individual fuses under dash,,4 for each door,,i only have power to the only one that works(drvr.wndw),.,.,..any suggestions//help would be greatly appreciated..thanx
jaydawg30 Feb 25, 2011 07:51 AM
yeah your window is binding up. does the window move out of the run channels?
tng6664 Feb 25, 2011 08:46 AM
The window posibbly stuck?ndividual fuses under dash,,4 for each door,,i only have power to the only one that works(drvr.wndw)
bucwheat Feb 25, 2011 10:22 AM
I would suggest first trying to get to the connections on the master switch in the drivers door by removing the door panel,check the connection and if the switch is getting power,if the switch is faulty replace it, they run about $125 on line.I have a feeling the connection is loose,let us know Good luck,Bobby
tng6664 Feb 26, 2011 10:46 PM
Help,,the master switch does have power,,the driver window works fine,you can hear clicking in the other doors when trying from main switch,,,the question is,,,there are 4 fuses for each window,,I checked with testlight there is only power to drvr wndw fuse,,which that one does work fine,,the other 3 individual fuses have no power at all.Is there a seperate relay or something,,this make no sense at all to me.
