| esmikell |
Oct 22, 2009 07:59 AM |
1987 Carb issues
Hello, my 1987 accord has some carb issues. Once at ops temp, fan has come on and off, rpms will race up to 4000rpm, sometimes. If I hit the gas it goes higher and then rests at 4000rpm. Now when it does idle, but not correctly, looking down the carb, while running warmed up, I feel like too much gas is coming out of the fuel jet. The one in the middle, not the power value jet. Now if I put a rag over the carb she RACES up in rpms. What is that? In the past when I had an air leak the rag trick would let the car idle correctly, now she races up when I cut air flow going into the top of the carb. Putting a rag over the secondary barrel does nothing. My fuel economy has dropped. At idle I have to push on the accelector to keep it alive, I guess because of too much gas going down the carb.
Please help, its my go to work car. Thanks
