1990 Accord Rack and Pinion
Can anyone tell me how difficult it is to replace my rack and pinion? The car is an LX sedan with automatic transmission...Anything else I should replace while the rack is out?
Thanks! |
the rack and pinion on that car is supposedly a 8 hour job. its not difficult just sort of a pain. can i ask what the steering is doing?? because in my98 civic i could turn the wheel 1/4 to both sides and the wheels wouldnt start to turn till after that. i almost payed 1k for the whole new rack and pinion replacement untill i got under the car while someone turned the steering wheel. it turns out a 1.98$ alignment bolt had fell out. so insteak of 1k i payed 1$ and my car was fine.
The power steering is very weak, sometimes non-existent. Often I need to use brute strength to turn the wheel if the car is not moving. Also it often whines when I turn a corner. I have checked the power steering fluid and it seems to be full. I think it's just time to replace it. It won't be a problem for me to replace it, I was just wondering if there were any funny things I needed to watch out for and if I could do it in an afternoon.
Thanks! |
its not too bad to replace one more thing you should check before replacing it is the pump unless youve already checked it. other that a million tiny parts you have to remove to get to the rack and pinion its not too bad.
| All times are GMT -5. The time now is 08:13 AM. |
