1991 honda accord alternator drive belt help
So i finally understand that the 91 accord ex has belt tensoners insted of a tension bolt but i still cant tighten the belt ans secondly i cant find the lower bolt to my alternator the top bolt is under the pully i got that one and also the tensioner however the manual says there is a 3rd bolt
Welcome in,this should help.
Locate the alternator on the front left-hand side of the engine. Loosen the upper and lower alternator mounting bolts by turning them counterclockwise with a ratchet and socket. Turn the adjustment bolt on the lower left-hand side of the alternator clockwise to tighten the belt and counterclockwise to loosen it. Tighten the alternator mounting bolts with the ratchet and socket. Locate the power steering pump on the front top side of the engine. Loosen the upper and lower mounting bolts by turning them counterclockwise with the ratchet and socket. Turn the adjustment bolt on the side of the power steering adjustment bracket clockwise to tighten the belt and counterclockwise to loosen it. Tighten the power steering pump mounting bolts with the ratchet and socket. |
May I be more help
Originally Posted by Ryan Stilwell
(Post 18478)
From, Brandon |
| All times are GMT -5. The time now is 08:18 AM. |
