1993 Honda Accord-- Air Condition Runs only on high
My Air Conditioner in my Car Only has 1 Speed. HIGH... Low, Medium, and Medium High turn on the Compressor, but not the fan.The fan only turns on when switch is on the high position...Is it the Dash panel switch or something else???
RE: 1993 Honda Accord-- Air Condition Runs only on high
I'm also new to the forum. Can't offer advice as I also have a similar problem except that I do not have any fan function. The 30 A Fuse is okay. Guess I'll have to take the Climate Control Panel out and test the switch unless another member has had similiar issues and can offer a resolution?
sometimes there are two relays that control fan speeds. one for low to med and the other one for high. It defintily sounds like the trouble is in the fan switches and not the ac. hope it helps
I was also told that there is a Resistor Pack that plugs into the Fan Motor... This might be the problem .. Only problem is it's a $ 124.00 part... Want to make sure this is it before I buy...
