1998 Accord Coupe Climate Control Issue
My '98 Accord only blows out blistering hot air and only to defrost. I cannot not adjust the temp or change the air output location. The fan control works so i can turn that off, but hot air still comes through. Below are the things i have tried:
What are some things i can try? Are there any control levers or manual mechanism that i can adjust to cold for the summer? Is there any electrical parts that commonly fail causing my issue? thanks for any advice! |
Update: I have discovered that the climate control panel is faulty. I also learned that manually closing the heater control valve by hand is tricky to know you are completely closed.
Take 2 on the bypass was a success, i forgot to burp the cooling system first time round. I am going to just leave it bypassed for now. |
Wow that was fast. Good thing you have fixed the issue by yourself.
