1998 Accord EX 2.3L Rear Engine Mount Removal/Installation
Old Oct 2, 2010 | 03:26 PM
scw1991's Avatar
Post 1998 Accord EX 2.3L Rear Engine Mount Removal/Installation
Just removed and installed a new rear engine mount for my wife's Accord with automatic transmisstion this morning. To make a long story short, this mount cannot be removed from the bottom of the car unless the left drive axle is removed. This was not an option, so I removed the mount from inside of the engine compartment by removing the rear engine mount bracket(s) and the one-piece rubber/plastic air intake assembly. Once the air intake assembly and rear engine mount bracket were removed, there was gobs of room to pull the engine mount out and install the new one. The engine mount bracket must be removed first in order to take out the rear engine mount. It was necesary to place a floor jack w/ block of wood under engine/transmission and elevate slightly to take the weight off of the the engine mount bracket prior to unbolting it from the engine block.
Old Oct 3, 2010 | 11:51 PM
jacksmith's Avatar
Oh that's a good information you have shred with us.Thanks for telling us and do share if there is any other problem.
Old Oct 4, 2010 | 11:31 AM
thank you for the info, much appreciated for all members.
Old Sep 7, 2023 | 09:22 PM
Albee's Avatar
Default Mounts
  1. is the Ex same as LX
Luke Gilpin
Aug 26, 2018 04:05 PM
danonearth
Jun 4, 2017 08:01 PM
mutantmotorworx
Apr 19, 2014 09:47 AM
ramo5150
Nov 17, 2008 11:24 PM
lws
Apr 19, 2007 12:34 PM
