Sponsored by:
Sponsored by:
2000 Honda Accord
Old 01-22-2018, 02:39 PM
Joker2018's Avatar
Default 2000 Honda Accord
Is there anyway to tell if head assembly is cracked.Also,Head gasket is blowed.
Old 01-23-2018, 02:39 AM
head gasket blown can be found by taking a compression check, there will be no compression or very low compression if the head gasket is blown. also need to be sure there is no air leaking through a bad valve intake or exhaust. another way to know if a head gasket is blown or crack head or block is water in the oil, or lots of air coming out of the radiator or overheating. sometimes if the valve cover is removed and engine running ( not always reccomended ) you can see air bubbles on the head if cracked. I've seen all the above. if the engine is still together, need more input of what is happening to get a better idea of a failure.
Old 01-23-2018, 08:34 AM
Also you may see white smoke or steam coming from the exhaust pipe.
Old 02-26-2018, 07:35 AM
hichamaziz's Avatar
misterix
03-13-2009 04:24 AM
ODUB
03-07-2009 06:52 AM
jfernandez1977
08-12-2008 11:53 PM
RotarySoldier
07-22-2006 05:59 PM
CindyNg
06-27-2006 01:18 PM
Quick Reply: 2000 Honda Accord
