2000 Honda Accord
I just bought a 2000 honda accord ex 4 cyl 5 speed . It seem like it is very (jerky) when changing gears and specially when in first when you let off the gas! Is this normal?
welcome to the forum. how much time do you have driving standard shifts, and if you have been driving standards for a long time and keeping the rpm's in the proper area, then it could be oil or some type of fluid on the clutch or clutch spring worn. how many miles does the accord have?
the car has 114000 and i dont know if has had the clutch replaced or not?Could it be the fly wheel? And i have been driving a stick for a while wouldnt say i am a race car material but i know how to drive normal! lmao
Plus its still (jerky) when in gear specially in first when you let of the gas!
does not sound like the fly wheel, nor the clutch. I need to do some research
The engine runs cherry! it revs very well and idles very smoth sounds good and runs good besides this issue!
do you see any oil leaks between the eng and trans parting case. has your transmission been serviced properly.
You might have worn engine mounts. Worn engine mounts are notorious for a delay in the acceleration department. Does your car have some type of a delayed start from zero to moving?
