2003 Accord Brake Problems
I hope this gets to those that are looking for this information. The 2003 Accords have a severe brake problem due to the use of front brake pads that damage the rotors. Honda has known about this for some time, as early as January 2003. They issued a Technical bulletin in October 2003 that applies to the front brakes of the models I will list below. If you have gone to the dealer and they denied the problem, such as Poway Honda in California did, do not take no for an answer. My car had less than 70% of the pad left at 14,000 miles and was 100% worn by 26,000 ( I saw them at the independent dealer). I had complained 5 times to Honda with complete denial of a problem. Then I went to a independent brake dealer (a friendly Meineke owner) ... He looked up the model for me and confirmed that the brakes were a known problem and printed out the Technical Bulletin stating the repair was to be done under warranty. Here is the information he gave me. Having this bulletin information changed the dealers view immediately. He replaced the brakes and had to refinish the rotors all for free. He did not blink at making the repair, once I gave him the paper, though he to had said "I've seen brakes go at 10,000. That is normal." All of the service advisors denied the problem even to the last moment, so I let them see the paper as well. If the service advisors don't know about this, go to another dealer and ask them if there is ANY technical bulletins, not just recalls, on your model. FYI, my car was out of warranty based on time and the manager wrote this was a one time "good will warranty" repair since I had documented that I had complained about this while under warranty. This should have been a mandatory recall!! I was going to the desert this weekend with my family and would have had NO BRAKES!! going down the steep mountains in San Diego.
Be careful, you may have no front brakes!!! My back brakes were still 90-100%, as we have a infant and don't drive erraditically. I hope this helps someone who is looking for information on this problem. I also filed a complaint on-line with the NHTSA. The Honda dealer had or should of had this information prior to my repeated visits complaining about the brakes. The noise had started at 4,000 and the cashier told me a LOT of people have had this problem (Of course, they paid for the work). Information to know, directly from the Honda bulletin obtained via ALLDATA retrieval service: Applies to 2003 Accord _ See Vechicles Affected Symptom- front brake noise or judder while braking Probable cause - the front brake pads have caused a variation in the brake disc thickness Corrective action Refinish front brake discs, and install new front brake pads. Vehicles Affected: 2003 Accord 2-door L-4 From VIN 1HGCM7...3A000001 thru 1HGMC7...3A027433 2003 Accord 2-door V6 (A?T only) - From VIN 1HGMC8...3A000001 thru 1HGCM8...3A036251 2003 Accord 4-door L4 Ohio built from VIN 1HGCM5...3A000001 thru 1HGCM5...3A101162 2003 Accord 4-door L4 Japan built from VIN JHGCM5...3A000001 thru JHGCM5...3A081070 2003 Accord 4-door L4 Mexico built from VIN begins with 3HG --all 2003 Accord 4-door V6 from VIN 1HGCM6...3A000001 thru 1HGCM6...3A101604 Warranty Claim information: IN warranty: the normal warranty applies (E.g. they should be paying for this!!) Operation #: 410103 Failed part: P/N 45022-SDA-A00 H/C 7138035 Defect Code: 07701 Symptom Code: 04213 Out of Warranty: may be eligible for good will warranty service, but must get district approval before doing work (THIS IS NOT TRUE, I got the work done the day I walked in with this bulletin without the approval of anyone but the dealer's service manager) |
2007 Honda Accord Brake Noise
Did you find anything on 2007 brake problems?
Good post.
now if only honda would do a recall for there faulty 01-03 transmissions that screwed over a bunch of people.
Doing the right thing is not in there vocab on that one
Cud b a bad caliper or bad hose..... hose cud b collapsed inside making a 1-way valve causing ur brakes to not release....
easiest way to find teh problem is jack up each wheel and free spin it by hand... the tire that doesnt want to spin is ur culprit |
| All times are GMT -5. The time now is 08:15 AM. |
