2016 Honda Accord blower motor not working
Bought a 2016 accord sport for my daughter at a auction last week and cannot get the blower motor working , I have another 16 accord so I’ve been swapping parts blower , resister and 40 amp fuse so far and all tested good in my other car , what else could it be ? Control panel ? It lights up and works though
If you apply volts direct to the motor does it work? If not you need to check the ground circuit.
Yes as I stated I put it in my other accord and it worked
Originally Posted by jstephens129
(Post 42895)
You are wasting a lot of time. We know we have a wiring issue. Check the power and ground to the one that does not work and put your other one back together and let it alone. I |
(Post 42896)
I'm talking about the one that does not work.
(Post 42898)
so you’re saying check the wiring to the blower motor ?
(Post 42900)
Yes. Put 12 volts on the motor. Does it run? If so we need to check the ground. What kind of understanding of electricity do you have?
I have a green and yellow wire to blower motor which one is power yellow ? |
(Post 42900)
You have a bad ground.
Do you know what grounds control blower motor so I can check them ?
