2023 Honda Accord Hybrid Tire Pressure
What is the correct tire pressure for this car which came with low profile tires? The drivers' door frame shows 33 front/32 rear but the car came with the tires inflated to 45 front/42 rear. Which is correct?
Use the numbers in the door. Pressure changes with temperature.
Tire pressure mischief
I have had scary tire pressure upon delivery with various cars. I had a 92 Acura where the tech read Max Tire pressure off the tire sidewall, inflated my tires to 45. I hit a pothole at Mile #8, tire exploded. A had a car delivered in Winter, the tech added “a little extra air pressure” but did that outside. First check in my 68 degree garage was 45psi all around.
Door jamb is correct, don’t check immediately after long high speed drive. Pressure rise in that setting, one of many reasons not to install 45 psi cold. |
