91 accord not starting
ok. my accord was doing fine for a few weeks, but then it decided to not want to start easily. when i turn the key, it just keeps turning over and not firing. but, it always eventually does start, sometime after 2 minutes, sometimes 20. i have to take a break from cranking for it to start. also sometime it will start and then after a second, just die. any ideas to what the problem could be?
RE: 91 accord not starting
my accord did the same thing. might wanna check your starter, an if not that then ur altenator. mine was my altenator, an im goin to be honest..... its a pain in the ass to change out man
fuel pump failing, distributor failing, spark plugs worn, main relay bad, ecu burnnt out. need to get a manual to assist you to complete the checks needed to see each item that may be failing or is bad.
