-   -   92 accord died while driving (https://hondaforum.com/forum/honda-accord-forum-11/92-accord-died-while-driving-3862/)
sadbuttrue08 May 17, 2009 09:12 AM
took the valve cover off and made sure the timing belt did not break it was good. checked fuel pressure its good. check for spark none. im not getting any spark at the coil. replaced the coil still nothing. there is 12 volts at the connector that plugs into the coil. idk what going on
acmech52 May 24, 2009 08:49 PM
welcome to the forum, it could be ignitor unit, main relay or ecu if coil is good and the distributor and rotor are good. if you go to autozone.com and register for free, you can go to repair and it will give you info to help you.
