92 Accord Idle Problem
Old 08-15-2008 | 05:41 PM
DanielH33's Avatar
Default 92 Accord Idle Problem
I'm having an Idle issue with my 92 Accord LX.
It Idles around 200-400 rpm. It accelerates, decelerates, and drives just fine, no problems at all. It doesn't Idle erratically (bounce up and down) though it has temporarily when I attempted to adjust the Idle Speed; my guess is that was the ECU trying to compensate.
I'm thinking this is either a vacuum problem or an electrical problem. I can rule out the Distributor Cap and the Main Fuel Relay. I cannot, however, rule out the Distributor itself. I want to jump on the IACV but I've been told this might not be the problem at all.
Anyone have any experience with this sort of issue? I'm getting a headache trying to diagnose the problem. Any help, suggestions, or advice would be apprectiated. Thanks!
Old 08-16-2008 | 04:40 AM
andry's Avatar
Member
Default RE: 92 Accord Idle Problem
do you have a vacuum leak? or you can reset the computer can make your idle normal (500 rpm - 750rpm).
Old 08-16-2008 | 12:42 PM
DanielH33's Avatar
Yeah, I'm looking for a vacuum leak. Never had to do that before, but I've been told what to do. I'll try resetting the computer, see what that does. thanks!
Old 08-17-2008 | 11:12 PM
dougster01's Avatar
Daniel, My 92 Accord EX has the same problem. I've replaced the spark plugs, distributor cap and rotor; and spark plug wires. I think it may be the IACV or fast idle valve. I haven't cleaned those yet. Let me know what you find out on your end. Thanks!
Old 08-18-2008 | 12:10 PM
DanielH33's Avatar
Cool, I will.
I've been told those aren't the problem, but I'm going to look into the anyway. I'll be checking my vacuum system within the next few days when I get a chance. I'll update on this thread. Thanks
bcole6
04-30-2013 10:30 AM
86_accord2.0
08-01-2007 06:50 PM
RotnikVW
02-28-2007 02:55 AM
alexk
02-02-2007 12:24 AM
BigDan
07-25-2006 01:22 AM
