92 accord leaking brake fluid
ok i see the leak spots underneath the resevoir/master cylinder. can't tell exactly where it's coming from though. anyone faced this same issue? is there stop-leak fluids that would slow this down, b/c this is my daily driver.
thanks. |
RE: 92 accord leaking brake fluid
There are no stop leak fluids for the brake system, this would gum up the system and have sluggish braking. Best to find the exact leak and replace with a overhauled or new unit. Do it on the weekend when not at work. or perhaps you may have loose lines , check for tightness.
i see. yea i guess i'll have to take the whole unit out when i have the time. ive never taken out the master cylinder, is there something i should look out for before i dismantle the whole unit off?
thanks btw... |
Go to autozone.com, sign in for free and go to repair, this site will show you pic's and instructions on how to r&r the master cyl. eamil me if you have more questions, Also Majestichonda.com does have a site to look for parts to view the breakdown, and estimated cost.
nice! i'll def contact you if i run into any issues. Thanks again!
| All times are GMT -5. The time now is 07:53 AM. |
