93 Honda Accord LX (Brake Lamp) indicator
Old Feb 14, 2008 | 11:48 PM
rodneylynn1977's Avatar
Default 93 Honda Accord LX (Brake Lamp) indicator
I am at a loss... I have a 93 Honda Accord and the Brake Lamp Indicator is on and all the bulbs are good...
Somebody help me
Old Feb 15, 2008 | 08:46 PM
dougster01's Avatar
Default RE: 93 Honda Accord LX (Brake Lamp) indicator
If you've checkedall 3 brake lights to ensure they are functioning - then you may want to try disconnecting the negative battery cable (as long as you have your radio code handy if still using factory radio) - waiting a few minutes to clear - then reconnecting the negative battery cable - and rechecking the function of your 3 brake lights.
Doug
Old Feb 18, 2008 | 10:08 PM
joed2222's Avatar
When dougster01 is talking about all three stop lights he means to check the brake light in the back window and both tail lights.
Joe
Old Mar 20, 2008 | 12:38 PM
bcarknee's Avatar
(Just a warning
be careful with the breaklamp in the back window. When i replaced mine it didnt go in right and ended up melting the plastic around it and smoked out my whole trunk.I let the light stay on because i dont trust putting the break lamp light back in.
Old May 22, 2008 | 08:35 PM
johnwiltfongjr's Avatar
Also check the unit located on the back of the tail light. Each of the fender mountedtail lights have one and if they go out (and mine did on the passenger side due to water intrusion), they will give you that indication.
Ralph113
Mar 29, 2015 06:45 AM
Ivan Teo
Mar 12, 2014 07:18 PM
phor3al9one6
Feb 22, 2009 09:39 PM
theokengineer
Jan 27, 2007 03:00 PM
proff
Sep 19, 2006 08:10 AM
