'94 Accord Air Conditioning Help
Hi all,
I just got a 1994 Honda Accord recently, my first Honda, this winter. I don't know where to ask for help but since things are getting hot now, I need to ask! I had my grandparents look at it for me when I was out of town, and they said the compressor worked. When I was about to buy the car, I didn't check it visually, although when I pressed the A/C button and I felt the idle change so I figured it was fine (although this may be electronically controlled, my other car A/C idle is changed at the carburetor). In retrospect they may have been looking at what I'm guessing is an air pump, closer to the top of the engine. Anyway, I realized it wasn't really blowing cold, and I tried to put some R-134 in (my dad does A/C work so he has tools for cars as well), but then we realized the compressor wasn't coming on. We're not sure if the compressor is dead or not. I have a couple of questions: 1) Do these compressors have low-pressure switches? How are they reset if so? Our pressures were a little low. 2) On the back of the compressor, there is a little dongle or something that has one red wire coming from the compressor to the plug, and the plug has a lot of wires going back into a main harness. However, the plug itself is not connected to anything. Is this a test plug or something, or does it need to be connected to something for the compressor to work? We didn't see any sort of plug-in for this in sight in reach of the wires, so we're not sure. I don't have an owners manual and couldn't find a wiring diagram online. Thanks for any help! |
RE: '94 Accord Air Conditioning Help
Aloha ouchevelless, welcome to the forum. If you go to autozone.com, and register your car for free, you can get all the a/c info and wire diagram for your car. the a/c is under chassis electrical. all under repair and maintenance. If you have more questions, continue a post. If you get a fix, post and we can all learnThanks
