96' Won't Crank
Long story short I had an oil leak. Took it in to get fixed and when I got home some of the leftover oil was on the exhaust. I sprayed degreaser on the motor and under the car and washed it off now the car won't even turn over. I have done this probably four times before, and this is the only time it has happened. I know I didn't get the DC wet. What's the next guilty party? Fuses?
That's a negative on the fuses being bad.
Will the head lights come on? Check your battery terminals make sure they are not corroded and tight.
It's a funny thing, when we send our Honda out for an oil change ,it dosen't matter who does it the spillage happens and the drips last days,so I put and old rubber backed rug down to catch the drips.Can't stand a grease floor.
Theres a single prong plug on your starter, try that. Whoever did your oil change might have hit it accidentally. they get unpluged quiete commonly. :)
Well then it shouldn't have started after the oil change.
She's back up and running guys.....check out my other thread if you guys need vinyl decals.
