97 accord dosent have spark after engine swap
I put in a jdm motor and its not getting spark, I need some help.
Welcome.
There are three, main, items that will keep the engine from getting a spark. A bad ignition coil, a bad igniter and a bad distributor. To check the ignition coil, measure the resistance between the +, black/yellow wire, terminal and the -, white/blue wire, terminal of the coil. The resistance should be about 0.6 to 0.8 ohms at 70° F. Then check the resistance between the +, black/yellow wire, terminal and the coil wire terminal. It should be about 12,000 to 19,200 ohms at 70° F. http://z.about.com/d/autorepair/1/0/Y/9/41938331.gif As for the igniter, if the tachometer is working, then the igniter is okay. Here is the procedure for checking the igniter.
