'98 Honda Accord Coupe - Turn Signal Problem
Suddenly my turn signals no longer work. I've checked the fuse, replaced the flash relay and replaced the multi-switch assembly on the steering column. Hazards work. What's left to look at? Help.
welcome to the forum. Have you checked the hazard switch itself, my accord hazards did work but the signals failed. I was advised to swap the hazard switch with a used one and our signals started to work.
My hazard button has been broken for about a year. I could turn the hazards on, but the button would not retract back out unless I pulled the assembly apart. I've ordered the new hazard switch and hope that this helps. I'll keep you posted and thanks for the feedback.
have you tried a salvage yard? I got most of my parts from a salvage yard, and was able to get a warranty for 1.00 the part cost 1/4 of new. I've had a 99 % parts work from salvage yards.
Turn signal problem solved
I replaced the hazard switch and the turn signals now work.:)
That ACMECH is a genus!
