-   -   AC and heat work on settings 3 and 4, but not on 1 and 2 (https://hondaforum.com/forum/honda-accord-forum-11/ac-heat-work-settings-3-4-but-not-1-2-a-4626/)
masduud Sep 28, 2009 09:37 PM
I also have a 2002 accord se with a new problem (AC and heat work on settings 3 and 4, but not on 1 and 2). I took it to midas and they checked it an said the blower motor resistor needs to be replaced. They said the part costs $200 and the total would be $300. I did some research online and found that you can fix it yourelf. The blower motor is under the glove compartment on the passenger side, but the pictures were from a 98 accord. Does anyone know if the blower motor is in the same location for the 02 accord? I found a new blower motor resister much cheaper on ebay. I also have a 2002 accord se with same problem (AC and heat on work on settings 3 and 4, but not on 1 and 2). I took it to midas and they checked it an said the blower motor resistor needs to be replaced. They said the part costs $200 and the total would be $300. I did some research online and found that you can fix it yourelf. The blower motor is under the glove compartment on the passenger side, but the pictures were from a 98 accord. Does anyone know if the blower motor is in the same location for the 02 accord? I found a new blower motor resister much cheaper on ebay.
08CRaVer Sep 29, 2009 05:21 PM
ummm
go to http://hondapartsnow.com
they have the part for cheap but they also have the digrams and the instructions to install it
masduud Sep 30, 2009 10:27 AM
thank you soooooo much. The part is only $52. Midas was going to charge $200 for the part and $100 for labor. I looked under the glove compartment and its just 2 screws holding the blower motor resistor. So it should be pretty easy. Thanks again!
08CRaVer Oct 8, 2009 01:57 PM
no problem, hope it all works out for you.
I love this webiste aint it great haha great prices too
glad to be of a assistance
slyko Jun 14, 2010 01:30 PM
You guys are Fantastic!
This forum is Fantastic!
It's listed under the heater/electrical as the blower motor resister!
It solved the problem?
johnfm3 Jun 16, 2010 11:59 PM
Thanks, I also have a 2002 accord that had the transmission problems @ 60,000 miles, the car now has 155,000 on it now and is still going strong. My 1 and 2 settings also don't work, so thanks for letting me know how to fix mine as well :)
slyko Jun 23, 2010 11:37 AM
That was it! The blower motor resistor. It took me all of 20 minutes to replace it!
The Haynes Repair Manual confirmed it too!
Ebay had a used one for $30, online for $78, and the dealer had it in stock for $90.
CRaVer YOU are an ACE!
