Bouncing Tach
Old 08-09-2012 | 04:17 PM
sloweddi's Avatar
Question Bouncing Tach
Howdy,
My 1989 Accord LXi has a problem with a bouncing tach.
The engine will surge with the bounce momentarily.
The Engine problem light does not come on.
I could not find a vacuum leak.
since it was time, I have replaced the Air cleaner, spark plugs, wires, PCV, Dist cap and rotor and cleaned the IAC. I tested between each part replacement.
All fluids are correct.
All that is left is the O2 sensor or I missed a vacuum leak.
Any thoughts??
Old 08-10-2012 | 04:45 AM
welcome to the forurm. Possible your speedometer cable is beginning to stick. or indicator bearing sticking.
Old 08-10-2012 | 11:57 AM
Welcome to the forum,check your ignition control module inside the distributer...that could be the cause or perhaps a sensor that is inside the distributer is bad,or a bad ground or coil.
Old 08-10-2012 | 01:17 PM
sloweddi's Avatar
I thought about those problems. I am hoping it is not the ICM as that is too expensive for me right now.
I did notice that the engine sort of revved with the tach for that second or two that it went up to 2 or 3K.
I will try the O2 sensor firat as they are under $30 for both.
Old 08-10-2012 | 04:33 PM
sloweddi's Avatar
I had a long talk with a local auto parts guy (races on weekends) and he said it might be that the IAC is stuck open, a vacuum leak, or a bubble in the system.
Being retired gives me lots of time to tinker so I will start with the least troublesome and work from there
Old 08-13-2012 | 01:25 PM
Please let us know what you find!
Old 10-06-2012 | 03:33 PM
sloweddi's Avatar
Well... after such a long absence I should explain I only get out of the house about one or two days a week now. No energy left and waiting for the next Cath lab opening at the V.A.
still have the same problem with the car except that sometimes it will be normal, no tach bouncing with the engine trying to catch up with the bounce, nice smooth engine and very good acceleration.
Now however, when it is at its worst, the "battery" light will come on for a moment and almost stall out. I have a helper today so we will be tearing into this problem. If they could have put the alternator in a worse place I do not know where that is.
Old 10-09-2012 | 04:05 AM
allexx's Avatar
IF YOU WANT TO KNOW ROCKING NEWS ABOUT YOUR BIKE
PLEASE VISIT
dainik bhasker
Old 10-09-2012 | 11:25 PM
lowlife9's Avatar
hmm could be the alternator you can have that tested for free i would also check all your ground wires to make sure none are loose.
PaulPool89
08-19-2014 07:40 PM
ToraEK9
04-01-2009 10:37 AM
panaphobic
03-13-2008 01:38 PM
ricebrnr10
07-26-2007 01:17 PM
rydnlow1120
07-20-2006 03:15 PM
